RSD559's avatar
RSD559
Adding an accumulator tank
I'm going to put in a 2 gallon residential accumulator tank. Went looking for the parts to hook it up. Couldn't find what I was looking for so I asked the Lowes guy. He told me that RVs usually have odd sized water lines and that I probably needed to get the T-fitting from an RV dealer. He said that the lines are most likely smaller than the residential stuff. Have any of you done this? Did you have problems with regular push-to-fit parts off the shelf?
The water heater is under the bottom full-sized bunk. 3/4 of the space under there is sealed off, and mostly empty. I plan on putting the tank under there and tie into the cold water line going to the water heater. Thanks.
Having RV issues? Connect with others who have been in your shoes.24,260 PostsLatest Activity: Jun 07, 2025
