Lee185
Aug 22, 2016Explorer
sfpcservice wrote:
Positive to switch, switch to 85, 86 to ground. Positive to 30, 87 to load.
Where does the wire from pin 7 connect?
I would assume it goes to the switch then to the relay leg 85?
The same goes for the positive wire from the battery, to the switch then to leg 30 correct?
As far as the switch goes, what I am going to use is a SPDT (Single pole double throw) marine grade toggle switch. It powers 1 of 2 circuits at a time (REV on, off, TT battery on) in order to be able to turn the lights on with the truck out of reverse.
Thanks, Lee
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
