gatorcq
Aug 25, 2016Explorer
Adding Lights will NOT void safety inspection. State regulates vehicle inspection and NOT DOT.
Please read the code prior to publishing. Then after you read it, Publish the Code along with the requirement number.
Someone ones stated what could NOT be used for Propane stating DOT. I published the requirement code showing what pipes were acceptable along with the paragraph section.
Now the brightness - can mean a big difference.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
