Lee185's avatar
Lee185
Adding backup lights, Wiring help needed.
I've been wanting to add backup lights to my TT for several years now.
I've read every single thread here & on other sites, my plan is to mount 4 LED flood lights, 2 on the rear bumper of the TT facing outward & 2 more in front of the TT tires facing outward.
I have verified my 7 pin is hot in reverse & the yellow "7 pin wire" is run back to the junction box where the trailer lights are conected to the umbilical cord.
I want them to come on when in reverse & be switch activated so that they stay on while unhitching/leveling.
I know I need to wire in a relay & I've done a bit of research on it & have a pretty good idea on how to do that, but my main question is which leg of the relay does the switch get wired into The 30 or 86?
The one thing I haven't found online is a "accurate" diagram of how to wire in reverse lights, using the 7 pin for power aswell as using the TT batteries for power along with using a switch "REV, off, on"
One other thing I came across recently was adding a "diode" inline on both the 7 pin wire & on the hot wire from the battery to prevent backfeeding?
Thanks, Lee
P.S. I use magnets & towels to cover the tail lights on my truck.
  • RoyB's avatar
    RoyB
    Explorer II
    Safety lights fall under US DOT regulations so it behooves one to check with them first before adding such lights.
    This may void your safety inspection...
    Only certain lights can be on the rear and front of towed units...
    You might get away putting them on the sides up high to the rear of the trailer...
    What you don't want is invest some monies into these kinds of lights only to have to remove them when it becomes inspection time. Talk to the JEEPS guys in California about adding lights...
    Not saying it can't be done but one should check on the requirements first. Even the lens of these light have to have DOT stamp approval numbers on them...
    Just saying...
    Roy Ken
