donn0128
Mar 29, 2016Explorer II
Sure you could, but why? In reality there is very little 120V stuff you should consider running off a battery bank. AC, NO, Microwave, maybe.
Since your converter is in the rear, dedicate a storage compartment close by to batteries, install and wire them directly to the converter, remove the house battery from under hood. If you want 120VAC for something specific, run a dedicated circuit from inverter to the desired location.
