MEXICOWANDERER
Mar 29, 2016Explorer
No free lunch and no miracles - sorry.
The simplist way is to run a 1/0 gauge cable under the chassis, to positive in the rear. Then pin both chassis negatives - both ends to the frame also using 1/0 wire.
I've adopted the Skycraft DLO diesel locomotive cable as my favorite because of it's tough and thick insulation. Light years tougher than battery or welding cable and the Skycraft sourced DLO cable is much less expensive. I use 1/4" poly rope as a route measuring device first then measure the rope before I buy the cable.
This way all the house batteries are ganged evenly and there will be much less confusion. Google SKYCRAFT SURPLUS FLORIDA. Then select WIRE and then DLO WIRE.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
