RoyB
Mar 29, 2016Explorer III
Have you looked under the steps leading up into the Class C. I hear alot of folks being able to have a couple of extra batteries mounted here.
You could be able to charge these batteries through your converter/charger setup...
You are aware that your current converter/charger has to be a single mode 13.6VDC Charger basis on the age of your Class C. When you start upgrading the batteries etc you really should look into upgrading your whole battery setup to a more modern multi-voltage converter/charger unit.
Just buying two new batteries and installing them as stand-alone batteries will in a short time make those batteries unusable and harmed beyond bringing them back alive to their original performance.
I can run down my 255AH battery bank to their 50% charge state over night just drawing DC amps for a very few list of things we want to run. This is mainly just pulling around 20AMPS Dc Current for 4 hours or so... I have to bring this battery bank back up to its 90% charge state the next morning if I want to use them again for the next day/night run. I can do this with my 2KW generator connected to my on-board mulit-mode smart mode charger PD-9260C Converter/charger unit in a three hour generator run time. If all I had was the 13.6 single mode charger it would take over 12 hours or of generator run time to bring them back.
If I was to just charge them for a couple of hours here and there they will not get their performance back enough to make the next nights run and would probably only last maybe just a few hour into the night. Once they get down to the the 50% charge lever (around 12.0VDC) then you need to stop using them otherwise you will start doing harm to the batteries.
So the best plan is install a modern battery system first then you can start doing camping off the battery bank and not destroy things...
If your running off the batteries is just running a led light then what you are implying would work great...
Back in the day we did just fine running off of a bag of D-CELL batteries and candles haha...
I got to have my basics HDTV, charging of my computer/tablets batteries, keeping my WX Radio going, a light or two on, and maybe a fan. The rest can be run off of propane...
my two cents worth haha...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
