enblethen
Apr 02, 2013Nomad
According to the installation instructions th power unit is set up for 50 amp service. You would need to jumper second half from an existing breaker output to heat up the other half.
If you have full size, one inch thick breakers you could buy thin wafer breakers to use as installed. I would be exrtremely careful; about jumpering the bus work.
PD4506
Look closely at drawing. It shows a red going to one breaker and black going to the other. Yours is set up with only the black.
PD4506
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
