jaxson3
May 22, 2013Explorer
enblethen wrote:
According to the installation instructions th power unit is set up for 50 amp service. You would need to jumper second half from an existing breaker output to heat up the other half.
If you have full size, one inch thick breakers you could buy thin wafer breakers to use as installed. I would be exrtremely careful; about jumpering the bus work with those circuit breakers. Look closely at drawing. It shows a red going to one breaker and black going to the other. Yours is set up with only the black.
What breaker was he using? Do you know the brand name? Was it cutler hammer, square d or maybe westinghouse?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
