time2roll
Nov 04, 2015Nomad
BobsYourUncle wrote:A warm carpet should get you across the RV in the middle of the night. pianotuna has the details. Just seems way less complicated than covering the belly.
I like a warm floor though, especially when I wander out to the potty at O-Dark Thirty and have bare feet.
Now you're in Ca, what's a cold night for you? A chilly 60 degrees? Lol!:B
I modified my water system after a freeze up at -10F up in Mammoth Lakes.
I also have added two additional heater ducts to get more hot air flow. OEM system was so bad I was constantly hitting the high limit switch even after propping open the collapsed oem floor plenum.
And so while anything less than 60F around here is considered freezing we have ventured into some actual snow areas.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
