TurnThePage
Dec 22, 2015Explorer
I added ac/dc heat pads to the tanks (two on the fresh water tank), used a little eternabond on several edges to ensure they stayed stuck. Surrounded the tanks with 1/2" foam board and filled the gaps with spray foam. Corroplast was then suspended between the I beams just to protect the foam. It's worked great for me for the last 10 years. Oh yeah, I also added an Ultrafab 12v pipe heater down near the drain valve, then thoroughly insulated the exposed drain pipes too. So far so good!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
