BobsYourUncle's avatar
Nov 04, 2015
Adding enclosed heated underbelly. Can it be done?
Perhaps an odd question but has anyone taken a regular 3 season TT and added the enclosed heated underbelly? I am not too familiar with what they do at the factory for this option but seems like perhaps it could be a doable thing. Can't see it being that difficult to achieve.
And then along the same line as that, what about doing the same for the tanks? I know I can add aftermarket tank heaters, that's not a problem.
I like winter camping and plan on doing a lot more of it now, especially after no longer bring FT and now have a S&B again. I miss those minus 30 nights in the TT! Haha!
But the old Topaz is a mite chilly and has an ice cold floor in those temperatures.
  • Factory runs a heat duct from furnace down thru sub-floor and into area of tanks so furnace can blow warm air into that area
    Then insulation is installed..........usually thinsulate type laid on the coroplast sheets that are used to enclose the underbelly.
    Coroplast is like plastic cardboard. Big box hardware/sign shops etc.
    Lots of self-tapping screws
    Seal up any openings/seams and call it done.
    Heat pads are also used for 'heated underbelly'.......either in addition to furnace duct (best method) or in lieu of the duct
    Heat pads can be 120V AC or 12V DC and are t-stat controlled.
  • Out of all the members of RV.Net, you would be the one with the best skills of getting this done!
    From what I hear, the factory installed a thick plastic under the RV and tanks, with insulation in between the floor and sub-floor plastic.
    Think of those 'for sale' or Garage sale signs that are about 1/4" thick with ribbed plastic. A sheet of that stuff 102" wide and long as the RV. Of course cut outs for the springs, and such. It is attached to the frame and sidewalls. Just don't apply 2" long #10 screws into the grey and black tanks! LOL.
    Good luck,
    Fred.
