Golden_HVAC
Dec 21, 2014Explorer
Hi,
All RV's come from the factory with a 12 volt battery charger. So if you where to plug in the RV to a inverter, it would turn on the charger, and quickly discharge the battery while the inverter might use 60 amps to run the 40 amp charger, and both will stop about 1 hour later.
What I would recommend, and it is very simple is buy a 500 watt inveter that plugs into a cigarette lighter. You can use a car charger to charge your cell phone, it will use barely 1 amp per hour from your RV battery, it is very energy efficient. Plugging in your inverter and turn it on, with no load the inverter will consume about 10 - 15 watts, or about 1 amp hour per hour it is on. Add a load, such as the 50 watt TV set, and the total load might be 60 watts or so, about 5 amp hours per hour.
Your group 27 battery is good for about 100 amp hours "Lab rating" but real world, you can draw out about 50 amp hours every day, without damage to the battery. Then need to recharge about 60 amp hours to make up for the lost amount in the charge cycle.
Your RV will consume about 35 amp hours to just run the CO meter, propane leak detector, and refrigerator, about what one 120 watt solar panel will collect in one day. So to get through a long weekend, a single 120 watt panel will recharge the batteries just enough to give you some additional power for the next day. But if you are consuming 70 AH daily, your batteries will be depleted in about 3 nights.
So I would recommend a pair of 100 - 150 watt solar panels. Panels larger than 150 watts might not fit on the roof, between the antenna, RV Roof vents, refrigerator or A/C covers. Shading is bad on the panels. You do want them elevated by about 1" above the roof surface, so they will get good air circulation under it, and keep it cooler.
I make my solar roof mounts out of 2" angle aluminum. I cut off 6" length, and drill three holes 3/16" for #10 screws into the roof, and a 5/16" hole for a 1/4-20 bolt into the solar panel framework. Rubber roof sealant between the mount and roof keeps out the water.
I ran my wires down through the refrigerator roof vent into the closet next to my refrigerator. I put the controller there. I would recommend a PWM controller.
SunElec.com They sell solar panels near $1 per rated watt!
I used grey direct burial UV rated # 10 Romex wire to run from the panels to the controller. It is good for about 15 amps max. Home Depot.
I installed a couple of cigarette lighter receptacles in my RV so I can use portable inverters in several locations. I used #10 wire to them, and used a 20 amp fuse. Most of the time I will never exceed 20 amps through the inverter (about 200 watts load).
You can plug in your cell car charger in the same locations.
Good luck on your installation.
Fred.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
