Tal_IL
9 years agoExplorer
Adding Inverter
I am thinking of adding a basic inverter to my class A rig. I just want to make a single outlet available in the kitchen. My layout will very easily allow me to connect a basic inverter to my house ba...
westend wrote:theoldwizard1 wrote:pianotuna wrote:
Hi,
Use #12 wire (or #10) from the inverter to the outlet you wish to install. Look for a 20 amp outlet at Home Depot.
#12 is overkill for a 2000 watt inverter. 14/2 Romex is fine.
If you would believe the NEC and best residential wiring practices, 12 AWG is the size of wire for that load. The load can be greater than 15 amps at 120V. Pianotuna is correct.
