MrWizard
Jun 15, 2017Moderator
Yes 110v power will pass thru while charging the batteries
You will have to set the fridge to LP manually
Because on automatic, it will run using the inverter, when the inverter is turned on for other things
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
