Talisman61
Jun 15, 2017Explorer
time2roll wrote:
Is this a 30 amp RV? APS750 is not going to pass through 30 amps.
More like 8 amps so no MW, A/C, hairdryer, or electric water heat.... even when plugged into utility power.
I think you are better to power up one branch circuit (or 2) that handles some light loads. Not power up the entire panel.
https://www.tripplite.com/750w-powerverter-APS750/
Hmm. There is only a single 25A breaker in the panel for the entire unit.
No A/C or MW. But if the unit limits pass through when connected to shore power then that's a problem. I never planned to run appliances through the inverter in Dc mode, but planned to have all those available when connected to shore/external genny.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
