MrWizard
Jun 15, 2017Moderator
You can't use this the way you have it drawn
You must understand that a combo inverter charger has a built in pass thru circuit that is relay switched between inverter and shore
The way you have the drawn
You are feeding the breaker/camper and the inverter while splitting the shore power which goes thru the unit then back to camper
While it is the same source it is dangerous and illegal
The inverter power will be going back to the shore cord thru the breaker
I suggest you use plugs to move camper power circuit back and forth or install a transfer switch
The Tripplite can stay wired to the battery
But can not wire the 120 from inverter back to the breaker circuit
The way you have drawn it
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
