Talisman61
Jun 16, 2017Explorer
time2roll wrote:
Here is some equipment to consider:
GoPower 150w sine wave inverter $150
You could spend more on a larger 300 watt inverter or spend less and get a MSW inverter. The smaller inverter also means you don't need monster 12v wire connection. I only recommend sine wave.
So just to clarify, since all of these inverters have outlets and are not hardwire mounts, I'd just wire a pigtail 15-5 plug into the transfer switch that just plugs into one of these inverters?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
