time2roll
Jun 16, 2017Nomad
Talisman61 wrote:Yes. The transfer switch I linked would just plug into the inverter.
So just to clarify, since all of these inverters have outlets and are not hardwire mounts, I'd just wire a pigtail 15-5 plug into the transfer switch that just plugs into one of these inverters?
The transfer switch also has hardwire input connection for the utility power coming off your 15 amp breaker.
Then an output connection to connect your branch circuit.
The charger would get power right after the breaker, before the switch.
Most inverters transition to hardwire at 1500 to 2000 watts rated.
Note the GoPower has very low idle draw if it gets left on and also has a provision for a remote power switch so you can hide it in a cabinet.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
