Talisman61
Jun 16, 2017Explorer
time2roll wrote:
Just wire the converter before the inverter and the power will flow correctly when plugged in. And no inverter charging loop on battery power.
And here do you mean wire the converter before the transfer switch? The inverter you linked should only be wired from Battery>Inverter 12v Input>Inverter 110v Output>Transfer switch right?
So I should have Shore Power > 15a breaker > Converter/Charger branched to Transfer Switch 110V Input?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
