- NinerBikesExplorerOk, I guess it's a really bad idea to mix battery chemistry's. Even AGM and flooded Lead Acid batteries. Mix and match is bad Juju.
This is the battery I bought for the QRP ham radio for power. LiPO
And today, I just flat out ordered this charger, which equalize charges each cell individually, every time,
4S charger
Already have a 120V inverter that can handle the charger plug in. Was hoping there was another way, but I guess this is the best way for what I have. - GordonThreeExplorerI guess I'm late to the party, sorry for trying to help.
- MrWizardModeratorIf it's April 1st, where is the spring weather
Did I sleep ALL winter, what happen to Feb and March - Canadian_RainbiExplorer
NinerBikes wrote:
There's a dirty old man down in Mexico right now, choking from laughter on this thread. I can feel it, 1500 km's away.
Speaking of MW, where has he been. :h It's just too quiet on here.
We'll be driving up that way in a couple of weeks. Yes, again (different jeep though) :B
Maybe I should drop in and surprise him. - GordonThreeExplorerNiner, can you post a link to the lithium batteries you're using? are they a "naked" battery back, or are they retrofit modules with a built in BMS / charge controller?
Just an off the cuff observation, but I don't think you'll have trouble charging a lithium pack as if it were an agm. Likely the agm charge voltage isn't high enough to fully charge the lithium, but that doesn't matter to a lithium. - grizzzmanExplorer
grizzzman wrote:
There are dc to dc "chemistry" modules that would separate the charging voltages. So...... it could be done and other methods as well.
Here is a link to a Chemistry module - Searching_UtExplorerYou could do it, but if you're asking if it can be done you're probably not up to building the electronics you'd need to be successful. I haven't really looked, but doubt you'd find plug and play type control circuits.
- NinerBikesExplorerI'm recovering from the Blue Marlin Fishing down at the Yacht Club down in Quartzsite, AZ.
- grizzzmanExplorerThere are dc to dc "chemistry" modules that would separate the charging voltages. So...... it could be done and other methods as well.
- 2oldmanExplorer IIHe's pulling our chains.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
