the_bear_II
Jul 23, 2015Explorer
Our Onan ran in 100 + heat for several days without any problem. It's in the same type of enclosure you described.
It seems like you may be suffering from vapor lock in the fuel system. I wonder if the fuel pump is going bad. If it's not pumping with enough pressure vapor lock can happen in high heat.
I've read where folks have added fans to help move the air in the generator compartment.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
