path1
Jul 23, 2015Explorer
I'm not an expert be any means but maybe this might help you?
After similar problems you mention I did a complete tune up (all except adjusting valves)and put in a new fuel pump. Solved my problems. But I should of looked more closely before buying the new fuel pump. I often think maybe the fuel pump might of been my problem all along.
I bought the new fuel pump before taking out the old one because I never changed one before and wanted to see what I was up against.
The elec connection had one blade that had strange marks on it. I often wonder if the entire problem was the connection. Maybe after getting warmed up it would wiggle lose or loose contact? On my new pump I also packed in some elec grease.
I think you have something else going on other than temps of normal heat. They are made to work in temps that we have. Which surprised me because using a temp gun it gets pretty hot in there. (I don't remember the temps off hand).
Just a heads up about fuel treatment? I also did mine thinking that might be the problem and a good preventive measure for the RV's entire fuel system. And I really didn't know how the old owner took care of it. Turns out the fuel treatment (Seafoam) did a fantastic job of cleaning the entire fuel system. So good in fact that I fouled out 2 injectors at about 1,000 miles after treating the fuel system.
Following an "injector" shop recommendations and after getting injectors cleaned out, I changed out the fuel filter and then changed it again every 2,500 miles (twice) and then every oil change after that.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
