opnspaces
Dec 27, 2021Navigator III
one last question for any of you who run an inverter generator. Currently my Honda 2000i basically idles when plugged in and charging. I assume this is because the charger is stuck at 13.6 volts.
If I go to a PD 45 or a PD 60 amp I'm assuming the generator is going to ramp up a bit and make some noise. Does your 60 amp charger cause the generator to really ramp up and put out some noise? Or does it still stay fairly low in the decibel range?
And back to dieseltruckdriver. Yes I agree solar is probably the best way to go, but I'm not there yet on it.
Thanks again everybody, I really appreciate the input.
