opnspaces
Dec 28, 2021Navigator III
Interesting on the 20%c vs .125c (assuming that correlates to 12.5%c) I won't pretend to understand much of this battery charging. But I've read enough of your posts to think that 20%c is probably taxing on the batteries. If there is truly only 15 minutes charging difference between a 45 and 60 amp unit I'll probably go with the 45 amp.
So now my decisions are the PD costs $215 from bestconverters.com It charges at 14.4/13.6/13.2. The PD has the pendant that I can use to force into bulk mode for 4 hours if I want to.
The Powermax is $170 (on the Powermax website) It charges a 14.6/13.6/13.2. the Powermax does not have a pendant, but I can manually adjust the output up to 16.5 volts to equalize. This is done at home with a multimeter and a screwdriver which I'm more than capable of.
The IOTA with IQ4 is $160 from Bestconverters.com. It looks like the IOTA outputs 14.8/13.6/13.4 I think I'm ruling out the IOTA because if the higher bulk and float levels.
I know the PD has a decent following as it works for people. But I'm wondering how much of the higher cost is really goodwill or perceived value and not anything to do with reliability or longevity over any other brand.
Does anybody recall or have any thoughts on the reliability of the Powermax line? I don't recall any real negative posts on here so it seems good. But at the same time I don't want to buy the Harbor Freight equivalent of the converter world.
