MitchF150
Sep 17, 2020Nomad
If your auto change is not leaking now, but you are fearful it will, then replace it.. Just keep it so when/if you sell the trailer, you can let the next person decide on it.
I personally have used the auto change feature and have never had an issue with it.. First one on a 2003 Prowler and worked great. Traded it in 2019 for the new Rockwood.
Loved it. I too check it and when I see green, I know it's still on the tank the lever is pointing to. I've had it switch on me many times between checks and when I see red, I move the lever to the other tank (cylinder for those that will get picky..) and know to get the other one filled at the next chance..
But, your trailer, your choice, do what works for you!
Good luck! Mitch
Good luck! Mitch
