Gdetrailer
Sep 18, 2020Explorer III
mr_andyj wrote:
You CAN have a leak and never smell it.
Trust me, Trust all of us who are telling you this. Only leaks that are big enough to give off enough scent can be detected by a human, small leaks are impossible to sniff-out with a nose.
If a leak is so "small" that you cannot detect the odorant it is not going to big enough to cause an explosion or fire.
In a RV, you really do not have very many pipe joints, pretty much all of those are OUTSIDE where even IF there was a tiny, tiny, tiny leak it will do no harm. If you are concerned about wasting propane from the tiny, tiny, tiny leak it will be so little lost that it most likely would take years to lose a few ounces of propane.
You have a far greater chance of the rubber hoses leaking propane through the PORES in RUBBER of the hoses (and yes, rubber has pores which is why tires lose pressure)..
Heck, I have a nearly 40 yr old RV, the only thing I have done with mine is changed out the old weather beaten cracked hoses.
I am not going to sweat an extremely small loss at one or two pipe joints that I cannot smell or even see soap bubbles (which by the way IS an "acceptable" test for natural and propane gas leaks).
When in doubt, hit all the connections with a soapy solution and wait a few minutes to see if you have bubbles..
Folks are scared silly and way over thinking this..
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
