valhalla360
Apr 28, 2021Navigator
If you are using the rig, unless you've disconnected all the 12v draws, you pretty much need to keep the charger on. Letting the battery run down low before recharging will wear it out faster than keeping it fully charged.
Check the water level once a month if you are worried.
Now if you have it in storage and plugged in...just make sure there are no 12v draws and it's fine...but then why leave it plugged in.
