May 07, 2021Explorer II
I had the same issue with my WFCO. I never saw float or bulk, just a constant 13.6V. It would sit plugged in for weeks with nothing but the fridge on AC and the CO detector powered and still wouldn't drop to 13.2V.
I built a low side switch using an AVR controller and a 90A MOSFET to connect the battery for 1 hour every 5 days. The MOSFET reverse diode allows the battery to be used if the converter loses power. It has a button to charge for 4 hours and reset the 5 day timer if needed. I remove the switch while traveling.
