images's avatar
images
After oil change tapping noise
Frustrated
Had oil changed and after that had a loud tapping noise that sounds like lifters that goes away after a couple of minutes, it then runs like a new car until the next morning after it sets all night.
The garage that did the oil change said they used Mobil synthetic blend oil.
A mechanic that i know suggested that I drain the Mobil out and refill with dino and a qt of marvel mystery oil to clean the engine, I did and ran it for a while with no change in the noise.
I drained that out and refilled it with dino because that is what I have always used and thats where I am at the moment with no change in the tapping noise.
2007 Saturn vue
3.5 ltr Honda engine
68000 miles
Oil 5w20
Any Ideas or experience with Saturn/Honda engines would be appreciated.
Thanks in advance.
Joe
  • Which oil filter? One installed may not have check valve. Some have them some don't. Some are in the engine some are in the filter!
  • Try another brand..it just is such a pinpoint solution to your problem. If that doesn't work, get it good and hot and drive it for a while, maybe an air bubble or particle of dirt is in an oil gallery and needs to be flushed out. If that doesn't work I can't think of anything but the lifter itself or associated parts-if oil pressure is ok.
  • TPI wrote:
    First thing I'd do is change the oil filter. Possibly defective or not to spec anti-drainback valve.
    Thought of that and to make sure I had the right one I purchased a couple of filters from the local GM Dealer, It made no difference.
  • First thing I'd do is change the oil filter. Possibly defective or not to spec anti-drainback valve.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
