Thanks jharrell - Appreciate your taking the time to insert the Magnum manual info.
On SOC - Had the Magnum on Auto for Efficiency. Over a period of time it's supposed to learn and adjust based upon the battery shifting life cycle (Older batteries do lose capacity as they age.). With my Absorb Ending set to SOC 100% for the life of the previous bank, Absorb charge would end at the 100% SOC mark. However it looks like when in storage (With the Solar Controller off, and only the Magnum maintaining the battery bank.), the Absorb cycle never got close to a Tapered Down to 4 Amps, which for the 800AH bank was the Fully Charged magic value. The term used to me by Lifeline, and on a few other threads, is that the battery bank 'walked down' gradually over the years. And without reaching the Ending Amps Fully Charge of 4 Amps - sulfation built up.
In hindsight, I should have periodically manually validated the bank was at true Full Charge, and then reset the SOC values on the Magnum. This would have kept the 'calculated SOC' more accurate.
Another fact I learned over the last few weeks is that the Magnum Charger portion logic has a significant design parameter problem for AGM's maintenance. When in storage for up 2-3 months at a time, we're plugged into a 15A outlet. We leave the MS2812 Inverter On (In case of power outages.), and the Charger On to maintain the batteries. Once the Magnum reached Full Charge via reaching 100% SOC (As displayed on Line 1 of the ARC-50 Remote Display.) - it will not go back into charge mode until after the voltage drops below 12.7V, so basically when it reaches 12.6V the charge will kick back on. But, it then kicks back on in Float Mode only, and only runs for 4 hours. From 12.6V level, Float mode for 4 hours will not bring the batteries back to Full Charge. The conclusion from talking to Magnum Tech Support, is that this contributed to my previous battery bank 'walking down', and sulfate build up.
The logic on maintaining AGM batteries, once the MS2812 has reached Full Charge as seen on Line 1 - are not optimum for AGM's in general, and even a bit worse for Lifeline's which have different voltage needs. When I asked the Tech Support about the AGM 1 Lifeline Setting, and could not the logic behind Full Charge kicking back into Charge mode be altered based upon this setting? Well yes, that would be better to support Lifeline and or in AGM 2 setting, other AGM batteries. But nothing in the works to do so. And if they did this, it would require a replacement Control Board (Which by the way, is their solution for me to use AGM 1 with the revised slightly higher voltage for Float values that Lifeline recommends in their Feb, 2017 Tech Manual. No software flashing update capability...
On Absorb End on Amps - Well sir I agree that the BMK-Meter is the thing to look at to get the best info of AH values in relation to what is going in/out of the battery bank at any given time. Say vs the Inverter values which are displayed on Line 2 of the ARC-50 Remote. (Line 1 may say Absorb; Line 2 may say DC 13.4V 16A.) However for the Absorb End setting to work well for me, at my banks 4 Amps. It was suggested that I turn off the Inverter (Which I leave on to support the fridge in case of power outages.). And that i turn off all other House battery draws. In my case the Salesman Switch inside the Front door does this. Talking with the Tech, if I did those two things, the Absorb End set to Amps would support me pretty dang well. But, I do leave my Inverter on, and it does have the idle draw. And I frankly leave my Salesman Switch on too, as I have other 12V minor draws on monitoring equipment I have on 7/24. So the best advise from the Tech was for me to 'estimate my at idle/parasitic' AH draws on the house battery, and then add my desired Ending Amps value onto this, and set that Amp Hour value on the Absorb End - Amps setting. (9-12A idle/parasitic House bank draw = 4A to be Fully Charged - would give me a range of between 13-16A to choose from. Too high, and it shuts down Absorb too early. Too low, and Absorb runs too long.
So it seems to me the Absorb End - Amps value is best used, and would work well, for those who have everything turned off in their coach. No inverter or parasitic draws. Now if I was in the coach like when we're using it for months at a time. I could manually monitor the Amps via the BMK-Meter Amps display. But while in storage, I'm not in the coach daily... And as mentioned, the dang values used by Magnum to wake up the Charge cycle once Fully Charged value is reached, as well as the going into Float only, are not supportive of my Lifelines. (With the new bank, in testing, once I knew for certain I was at Fully Charged status on the battery. I monitored the SOC values daily over three days. I was down to 81% SOC, and the Voltage was still above the 12.6V needed to goose the Charger back on. So lots of up/down of battery usage, and then again, the Float for 4 hours would not get the bank back to full charge.....)
So the MS2812 for my way of storage is not too supportive of maintaining the Lifelines.
And don't get me wrong. I like Magnum, I like the MS2812, especially when I bought about 6 years ago - it seemed to be the best selection at that time for us. Would like to see Magnum make some logic changes, and while I would prefer for those changes to be software update patches, I'd be OK with buying and installing a new Control Board to get them. The Magnum, and all of their related components, play well together with my coach. (MS2812/AGS/SBC/Temp Sensor/ARC-50/Etc.) Timing of my Solar install missed the PT100 Controller by about 6-8 months. I would have liked to have had that, as then I'd have had the full Magnum component set - and they should have played well with each other:)!).
On the comment about reaching the Lifeline recommended Ending Amp at .5 Amp per 100A capacity, 4A for my 800AH bank - that is what I'm doing (And also validating that I have the settings set properly.). I've turned back on my MidNite Classic 150 controller. I do have the WhzBngJr module, which does support the usage of what MidNite calls 'Ending Amps' value. It's set to 4Amp.
So while in storage here is what I'm doing:
-Magnum Inverter on, charger on Standby
-MidNite Classic 150 Controller on, and Ending Amp used to stop Absorb, with Temp Sensor enabled
-I checked every AM for a about 8 days, and about 6:00AM each day, the BMK-Meter and MidNite Classic Display SOC values indicate 98% SOC. This is the idle/parasitic 12V draw on the house bank
Note: To confirm, ALL In/Out of the House bank is via the BMK-Meter Kits Shunt Valve. Nothing is attached directly to the House Bank.
-My 1200W of panels get good sun from about 7:30AM to 2:00PM (Where it is parked next door at our other house, it has a two story garage/apartment 5' to the West of it. So around 2:00PM or so the panels start shading.
-The four to five times I've had the time to go check during the day, usually by around 10:30AM the MidNite is displaying Float mode.
So getting some draw down on the battery bank from the inverter and parasitic draw, and recovering to full charge per Ending Amp of 4A each day. Then float maintain until it shifts to MidNite's 'Resting' status.
I've said this on other threads, and even other sites. Smart Battery Chargers are not always all that smart:)! For those who do no mind replacing battery banks on a shorter lifecycle due to possible less then ideal battery maintenance - these charges do an adequate job. For owners that have expensive battery banks, and want to optimize the lifecycle - these chargers require manual augmentation of hand's on monitoring, and manual override of 'auto' only control.
So different owner's with different approaches can come at battery management from different perspectives. And that's just fine... The danger is for those owner's that believe Smart Chargers are capable of 100% efficient management of their battery bank under all conditions - from what I can see this not the case.
For me personally I've shifted from letting the Smart Charger handle everything (As I assumed they were doing the job well.), to one where I'll be much more hands on in monitoring and managing the care and feeding of this replacement bank of X's 4 Lifeline L16's.
My next task is to completely review the MidNite Classic 150 settings. (I have done a quick look, to confirm Absorb/Float values as well as the WhzBngJr and Ending Amps value of 4A.) What I have never done, is successful upgrade of the Classic Software (To get the WhzbngJr update added, I had to get help from Starlight Solar's Larry - who had to talk with MidNite, as it did not flow/update for him too. Finally got it done with Larry talking with MidNite tech support:)!). As they have a new software release, I'm going to try to do this one on my own and see how it goes. The Classic 150 has some great download/logging files, that I have never bothered learning how to access. So that is on my To Do tasks list too. This should be my best monitoring tool on the condition of my Battery Bank going forward.
The DW has a large list of 'non RV' items for me to accomplish, and since we will not be head out until late June - the MidNite deeper dive will be over the next few months.
Finally (Yep, long winded:)!), I can only go with what I learn as I go along. I ask Lifeline, Magnum and in the future MidNite Tech Support for help and guidance as I work my way thru the knowledge curve. And I have found that sometime's a companies Tech Support technician's can provide different answers, or by accident incorrect info, at times. (Went thru this when talking with Magnum last year on SBC issues. Honest mistakes happen.). And I also admit that at my level of knowledge, at times I may not fully have understood what a Tech was saying to me. I've had many times when I thought I understood, even said it back to a Tech in my own wording and had them confirm I 'got it' - to later find that we were both wrong. Often,it is members on forums such as this that help clarify and or correct things:)!).
Great asset to have here, with everyone helping each other. And the is what all RV'ing is about, like minded enthusiast all helping each other...
Best to you, and all,
Smitty
