Naio's avatar
Naio
Explorer II
Jun 29, 2018
AGM battery test results and what should I do next?
I have 5 AGM batteries: 1 new for the chassis, and 5 used Fiamms for the house. All have their quirks. I want to report back on how I've tested them this week, and hear you folks' thoughts on what I should do next.
Chassis: I bought the newest I could get locally, 6 months old. Couldn't get it above 12.85 volts with the meanwell. I tried running it down to 12.00 and recharging.
This seemed to help -- it got up to 12.91 the first time I did it and 12.93 the second time. But after sitting for a week, with the negative post disconnected, it is back to its old 12.85v.
Should I exchange this battery? If so, any tips on choosing a better one for the next try? I can ask the shop if they can order me a fresher one...
House: These are 4 Fiamm telecom batteries I bought used a couple years ago, and have been sitting ever since with occasional top offs, due to health and life problems. I want to use them! I tested them using a 40 amp load (a space heater and MSW inverter).
Problem is, I didn't realize that the smart charger I was using to top them off was sometimes quitting early. (It's been a great charger for me for many years, but either it has developed a problem or it just doesn't get along with the Fiamms. It has a lifetime warranty, so I'm thinking I will call tech support when I get around to it.)
Anyway, the upshot is that when I started the test the batteries were not at their true full voltage :(.
Battery A:
12.67 starting voltage.
I tested this battery first, and the terminals got so warm it scared me off. After 4 minutes it was 108 degrees, and 12.06 volts, so I chickened out and switched off the load. Temp went up to 111 degrees. Voltage was 12.51 about a minute after shutting off the load and 12.54v 20 minutes later (77 degrees).
I put the meanwell on it at 14.55v to 2.8 amps. After charging, and resting for 2 hours it was at 13.10 volts, the next day 13.00, and the following day 12.96v.
What do you all think about the temperature under load for this battery?
Battery B:
12.54 starting voltage.
11.87 under load at 10 minutes, 108 degrees (at the end, but it stayed 95 to 98 through most of the test, so I didn't get scared). 30 seconds after removing load 12.39 volts, 12.49 after 20 minutes.
After the test, I kept messing with the meanwell trying to get this battery to charge to a higher voltage. The van is in storage and my access is limited, so I was doing it on a timer a few hours per day.
Yesterday it was at 12.74v, and when I put the meanwell back on it at 14.37v, it was taking about 1amp. I put the meanwell on the timer for a few hours, but the timer failed and the meanwell was on for about 22 hours. When I got it today, it was reading about 0.4 amps. I will see tomorrow what the voltage is. I hope I haven't hurt this battery.
Does its low voltage under load mean that it was not good to start with? Would it be a problem if paired with another battery?
Battery C:
12.75v start.
12.12v and 99 degrees under load. 30 seconds after taking load off, 12.55v, and 12.65 after 20 minutes.
Meanwell on overnight at 14.37. Still taking 2.83 amps in the morning, but I took the charger off. Subsequent days, resting voltage 13.23 and 13.14 so I think is full. A healthy battery?
Battery D:
12.66 starting voltage.
After 10 minutes load, 101 degrees, 11.99v under load. After 30 seconds no load, 12.47 volts. I forgot to check the 20-minute voltage.
Meanwell at 14.37v to 0.4 amps, resting voltage now 12.94v.
So, what do you all think of the performance of these batteries? If they are all good, I will put them into banks of two. Suggestions welcome for which pairs will work best together.
Or, are there other tests that I ought to run, now that the batteries are fully charged? (I realize more data is always better, but please keep in mind that I will have very limited days to work on the van before snowbirding in it this fall, and a day that I spend on batteries is a day that I don't spend on something else.)
Speaking of, I do have more data. If you folks have questions, it's possibly might have answers. I took measurements about halfway through each test, and have notes on my charging, which took place over quite a few days in little increments.
Thank you all SO MUCH for reading this mega-post, and for any ideas you have. I feel pretty clueless compared to some of you.
Having RV issues? Connect with others who have been in your shoes.24,316 PostsLatest Activity: Sep 12, 2025
