way2roll
Jul 29, 2024Trailblazer
Look around in your compartments, perhaps mounted to the roof of one of the compartments or near the generator itself. Since this appears to be a new RV, you could simply call the dealer or ask Thor directly.
Sbtuckmail
Jul 29, 2024Explorer
Thanks for all of the help. I finally found the AGS - Thor 28A. The module is located under a table seat in a screwed down compartment. Basically all of the wiring is under the seat and AGS is mounted to the floor. Same compartment with the fuse box. However, apparently the sensor switch is bad and not functioning, so a warranty item I hope.
