pianotuna
Aug 07, 2016Nomad III
Further when the air runs for hours at a time the energy consumption goes up. It may be important to watch the voltage.
The 13500 btu unit in my class C starts out at about 1200 watts--but I have seen over 1900, too.
If I've been driving for a couple of hours the roof air takes a long long time to cycle. The heat from the engine and transmission radiate up through the floor. The engine weighs about 640 pounds and if it is at 200 F then it has a heat content of about 9000 btu's (assuming I get it to 80 f). The transmission weighs a further 275 pounds.
I finally have an autoformer and I'd recommend one in a flash. The unit I purchased goes into boost mode immediately when the roof air starts. Then after the compressor is up to speed it drops out.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
