para1766's avatar
para1766
air conditioner recall now not working
I have a 2016 premier bullet by keystone that had a wiring recall on a/c. I took it to service center and had recall fixed now a/c will not blow blow cool air. Compressor is kicking on but just warm air comes out. It is a 2016 and only been on two camping trips. Anyone with any ideas. Seeing as how the one year warranty just went out.
  • The wiring recall has zero chance to mess this up- it is all done from inside- the Dometic has 2 power lines at the control box- one power in, the other power out to the thermostat. Keystone lust used one, connecting the thermostat power and box power together, which is not good. They basically had no reason to do anything on the roof unit.
  • Chris Bryant wrote:
    The timing vis-a-vis the recall was just a coincidence .
    Well you don't know that quite yet.
    Partly because we don't know for sure that the compressor IS running.
  • unless they damaged a line
    things DO happen
    it should be taken back and checked
  • If the compressor is running but it is not cooling, it has a leak, and needs to be replaced. The timing vis-a-vis the recall was just a coincidence .
    I think you should take it BACK to the place that did the recall repair. There is a good chance that they screwed something up in the process.....and the expiration date of your original warranty should mean nothing.
