JiminDenver
Nov 08, 2014Explorer II
Air conditioning on solar
So today I put together the three solar systems on the 8-D, hooked up the PowerJack inverter and then the 5000 BTU air conditioner. The Air conditioner is a Frigidaire unit that uses 446w/ 3.9a @120v. I fired it all up and was noticing that I the solar was no where near the 50a max it is capable of and the battery stayed in float.
Unfortunately the power jack PSW inverter did not like the experience and it's voltage started jumping around, so I'll be looking for a more robust unit. I'm not sure if I can fix it or if it's worth it.
