Hi,
The good part is the inverter did not blow up the air conditioner.
You also have "proof of concept" which is nice to know.
If you went for a fine quality inverter you might be able to run the roof air. It would cool about twice as fast as the window unit. I expect the 8d might show some voltage drop with that kind of load--and then the solar would max itself out trying to support the draw. The magnum I have doesn't even hiccup with the load from the roof air.
JiminDenver wrote:
Hi Don
The 3000/6000 PSW was suppose to be the NEW series for them. Same ol, same ol it seems. In any event I knew I was taking a chance, I was just hoping doubling the size to the loads I was running would make a difference. I knew you had said not to try the AC but yeesh, this one was 446w. Oh well, lesson learned.
At least I got to use it for a season and it showed me what our solar can do. I'm still trilled to know the solar can power the window shaker on its own even if I need to find a inverter that can handle it.
