JiminDenver's avatar
JiminDenver
Explorer II
Nov 08, 2014
Air conditioning on solar
So today I put together the three solar systems on the 8-D, hooked up the PowerJack inverter and then the 5000 BTU air conditioner. The Air conditioner is a Frigidaire unit that uses 446w/ 3.9a @120v. I fired it all up and was noticing that I the solar was no where near the 50a max it is capable of and the battery stayed in float.
Unfortunately the power jack PSW inverter did not like the experience and it's voltage started jumping around, so I'll be looking for a more robust unit. I'm not sure if I can fix it or if it's worth it.
  • Pure sine wave is nice
    But
    A Trip-Lite Powerverter PV 1250 will handle it easy
    Made to run motors it has a big heavy transformer in it.
    About $300 on Amazon, mine had been running my residential fridge for (4) years
    Along with drills, grinders, skill saw, and electric chain saw
  • 2oldman wrote:
    Is it a 'relatively inexpensive' inverter?
    Oh yeah it is. It's run the 1375w microwave, coffee maker and such just fine until now. That's the risk I take and sometimes it doesn't work out.
    Now that I know the solar will provide, I will start looking for a decent inverter again. Sometimes I use the toys to figure out just what I want without spending a fortune first.
  • RoyB's avatar
    RoyB
    Explorer II
    Good Show Mr Jim... I have run my 8000 BTU Window Air Conditioner a couple of times off my INVERTER running off my battery bank... The 8K A/C runs great on my 2KW Honda Generator too haha...
    With the looming power grid threats ongoing now solar system may be a big PLAN B items for all of us...
    I think MENA runs his A/C all the time off his massive battery banks (Might have been Mr Don) One of those dudes that lives 24/7 in their RV setup...
    Roy Ken
  • MEXICOWANDERER wrote:
    Panels mounted flat I penciled 3.22 as the amount of energy and storage needed (panels and battery) at a latitude of 22 to sustain 24 hour AC. That was computed using a 10.7 EER 5K window unit, and 88% efficiency inverter.
    Luckily I will only need Ac a few hours a day, mid summer. Even then night time temps are 30s and 40F usually.
  • Golden_HVAC wrote:
    If you are running a high torque motor, such as a refrigerator or A/C compressor, then you need to have a pure sign wave inverter, not modified sine wave.
    You probably need to oversize the inverter to about 1,000 watts as well,
    Good luck,
    Fred.
    The Power Jack is a 3000/6000w PSW inverter.
  • Panels mounted flat I penciled 3.22 as the amount of energy and storage needed (panels and battery) at a latitude of 22 to sustain 24 hour AC. That was computed using a 10.7 EER 5K window unit, and 88% efficiency inverter.
  • If you are running a high torque motor, such as a refrigerator or A/C compressor, then you need to have a pure sign wave inverter, not modified sine wave.
    Good luck,
    Fred.
