wanderingaimles
Sep 03, 2017Explorer
Your running on a 20 amp breaker, and another post you said the coffee pot has started doing it too.
Most likely your voltage is dropping on the feed line at least intermittently. And as voltage drops, your appliance or gadget makes up for it by drawing more amps,,,, and pop goes the breaker.
change the breaker, if it helps, great. If not, you may have to change the wire and outlet to a 30 amp feed.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
