2005 Newmar with air horns that do not work. The fuse 50amp fuse for the horn/pcm is not blown. Any idea of what to check to figure out where the problem might be.
Not a clue. Come to think of it, the horns could be run off the onboard air compressor for your air bags suspension if you have that.
If not it would seem likely that the horns won't be too far away from the compressor to lessen time lag. Find the horns and follow the air lines. Good luck.
