- azrvingExplorerProper fittings have nitrile o rings. Also use the proper Teflon tape (yellow) or a good sealant like Jomars.
- wa8yxmExplorer IIIMany air hose fittings tend to leak a bit, the tolerances and seals are not all that great.. I would NOT consider using them for propane.
After all.. The instructor was reading the quesion: "What happens if you get the proper mix of propane and air and there is a spark?"
I chimed up from across the room where I was doing my web thing.... "You land two counties over".. After the laughter died.. the instructor said "Exactly". - JaxDadExplorer IIIBesides, using air fittings in a gas system is illegal, you'd have to change them before you sold the RV so why not just do it right the first time?
If cost is a concern, even if the '1/2 psi fireball' isn't, just think how much a leaky fitting is going to cost you in propane. - Happy_ProspectoExplorer
RSD559 wrote:
I put in a Camco propane quick connect kit for my BBQ on the exterior of my trailer. On the BBQ side of the hose is there a problem with using air hose quick connect fittings?
What could possibly go wrong here? But I saved $5.00. - Dannyabear1ExplorerThe o-rings seals in them are generally different material also
- RSD559ExplorerPoint well made. That's why I asked. Lots of good info and experience here. Don't want to deal with leaky gas fittings. Thanks.
- MmwtdhExplorerNope.
Over the years I've had hundreds of air quick connects, tried them all, L, M, N, etc.
I've never walked through my repair shop, my fleet operation or my wood shop without hearing air leak or hearing compressor run when no one is using tools.... - RSD559ExplorerOK, OK! Off to Wally World I go. Hate to have a 1/2 psi fireball at the BBQ!
- bobsallyhExplorer IIMy propane quick connectors have a shut-off lever on them and you can't separate the connectors until the lever is in the closed position. Works well.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
