scorpionExplorerJul 29, 2015Airtabs on Rubber RoofInterested in hearing of any users of Airtabs who have them installed on their rubber roof RV's. Do they stick on?? Any problems with roof membrane lift etc??Scorp.
16 RepliesReplies sorted by NewestShow MorervroofinstallerExplorerJul 29, 2015If anything use bytle tape between the roof and Air Tab then screw down the cover the screws with a 4" fiber backed seam tape and coat.IAMICHABODExplorer IIIJul 29, 2015Ron3rd,Here is all there is to know about Air Tabs Just click around.Air tabsAlso a few threads on the subject.HERE And HEREThey may have some answers for you.On Edit: I found a video of someone that put them on a rubber roof,I have the same model only in a class C and it has a rubber roof.Air Tab InstallronfishermanModeratorJul 29, 2015You could put a strip of EternaBond under the AirTabs.ereed52ExplorerJul 29, 2015Click here for info airtabsjholtExplorerJul 29, 2015I don't think they will stick to a rubber roof.It has to be a smooth surface to stick.Ron3rdExplorer IIIJul 29, 2015I'm not sure what Airtabs are.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
