Flay_Crosswell's avatar
Mar 09, 2016
Algae in fuel
I have a 98 tradition w/300 cummins. It was a 1 owner when we bought it 4 years ago , I have been adding fuel conditioner every fill up and she gets used every 6 weeks or so . I have it in for routine annual service ,at a Cummins RV shop, and have been informed that the tank has Algae ,needs to be dropped and cleaned $$$$ ,It didn't affect performance at all but the filter is loaded . How do I keep this from happening again? Being a 98 is a long time , maybe it just caught up with me . Thanks
  • I may have as much or more experience with alge in fuel. Get the biocide from a store that deals with marine products, West Marine is one. Fishing boats deal with alge often enough. The biocide added at the refinery is not good enough sometimes.
  • Killem is the biocide product for diesel fuel I have seen the most often.
    Killem link.
    Be careful handling it.
    Water and diesel will allow that slime to grow at the interface level (water on the bottom, bacteria in the middle, diesel on top). The bacteria live in the water and feed on the diesel. Killem is lighter than water and heavier than diesel, so it will float at the interface between the water and diesel and will kill the bacteria. The problem is worse in warm temperatures.
  • Flay Crosswell wrote:
    I have decided to have them change the filters now and check the filters in a few months . I will treat the fuel and keep an eye on it and rely on both my filters to do their job. There is an additive called Diesel Tech for boats/algae problems. I have never lost power , chugged or had the check engine light come on . Thanks to all for your responses , the guy at the Cummins center agreed with me .
    Good plan. Have the fuel from the filters tested see what you are dealing with. It's a waste of money to buy treatment you don't need.
  • If your filter is loaded, it is hard to believe your performance was not affected.
    Define "LOADED"
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
