StirCrazy
Jul 14, 2023Moderator
pianotuna wrote:
enblethen,
It is an odd situation. There are two shore power cords--but one is hot and ground the other is neutral. Whoever did it used wire nuts.
There is also a 15 to xx dogbone. That has some melting where it plugs into a #12 cord. The cord is quite long.
The only number I'm sure of is 114 volts under load.
Um.. why don't you fix that with a proper cable and a new adapter while you're at it
