tarnold's avatar
tarnold
Alternator amps?
1997 E350 6.8 . How can I tell what is the rated amps for this alternator? There are no visible tags or markings. A place I read says all 6.8 have 130 amp, another says could be 110 or 130. Nothing in my Ford book says.
  • I'm lazy. When I see purple wires it means the alternator is 130 amperes :) Automatically, the large case. But your way works too BFL13. But it does not zero in on the amperage of the large frame. Green wires is a lesser amperage unit.
  • Copied from previous post link:
    3Gs come in two sizes: A a 7-inch “small case” and an 8.25-inch “large case.” Both can be found in 95- and 130-amp versions. The 95-amp model is easily identifiable by three sets of four round cooling holes in the case’s ribs that make a “Y” behind the pulley. A 130-amp high-output version uses three sets of two big cooling holes in the “Y.”
  • Get a flashlight.
    Look down at the alternator
    And through the ventilation holes
    What color insulation is on the wires?
  • 95 or 130 amp
    Look clsely on the coil assembly. It may have the identification inscribed on it. You may need to use some steel wool to high light it.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
