YC_1
May 23, 2017Nomad
Find a place you can make a solid ground for this issue and in the future. I promise you it will be helpful. Build a jumper wire long enough to reach throughout the RV. Now, as suggested, use the same ground because an invalid ground reference will make you crazy and misdiagnose things.
Make sure you used the correct bulb and that it is inserted correctly. I have seen wrong bulbs stuffed into sockets.
