time2roll
Mar 03, 2015Nomad
Yes the lights are low power and can all be on one switch.
No you will need to add an inverter and transfer switch to power the outlets from the battery.
As long as you are pulling wire I would go #4 for the main battery cables to improve charging. The 6v batteries need to be wired in series. Need about 50 amp fuse near the + battery terminal.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
