westend
Mar 03, 2015Explorer
In your diagram the water pump is on the same switch as the lights. It does not need to be switched and should have larger wire than 20 AWG. The pumps draw approx. 4 amps so 12 AWG or 14 AWG are good wire sizes. Also, you have the LED floodlight and the cabin lights as on the same switch. I would think you need to switch them separately.
You probably know all this and it may be the diagram that is leading me astray.
Good luck with your wiring project.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
