JennyMom
May 21, 2019Explorer
Amp Adaptors
I am new to RVing. I am trying to book a site that has 100amp hookup. I only have 30 amp RV. where do I get an adaptor for a 100 amp to 30 amps Adaptor. I found 50 to 30 but nothing for 100 amps.
myredracer wrote:
It can't possibly be 100 amps if it's a CG/RV park. Code requires either a 30 amp at 120 volts or 50 amps at 120/240 volts (like in a house), or both on a site. Maybe they are incorrectly referring to a standard 50 amp site as 100 amps because a 50 amp pedestal/site has two hot legs that give you the same amount of power as 100 amps at 120 volts.
If you have a 30 amp RV, a standard RV 30 to 50 amp adapter is a good thing to have regardless. The receptacles in 30 amp pedestals can sometimes be in poor condition and you may need to plug into the 50 amps in a pedestal or move to another site with 50 amps.
Up until 2017, the code (NEC) only required a CG to have 20% of sites to be 50 amps (and only 5% in older CGs) and getting 50 amps can be difficult sometimes, if not impossible and 30 amps is usually what's mostly available.
I do not think that the NEC "requires" anything.
It is not a Federal Law.
"The National Electrical Code (NEC), or NFPA 70, is a regionally adoptable
standard for the safe installation of electrical wiring and equipment in the United States."
It is not, regardless of containing the word "National" a Federal Law.
Additionally, the NEC is really the minimum standard, you can be safer than the standard for safe installation. Like wearing a belt and braces.
2oldman wrote:
Maybe she'll come back now.
D.E.Bishop wrote:RVIA has "adopted" the NEC rules and the manufacturers do follow the rules, at least they should be. The only thing with that is not being an authority having jurisdiction, they can't enforce the rules, levy any penalties or modify the rules. RV parks on the other hand would have to comply with a local AHJ and NEC. Not sure where in an RV you'd want to do better than the min. NEC rules? Possibly in buildings, but not that often. The problem with electrical in RVs is substandard workmanship and there's little or nothing an RV owner can do about it.
Dutch_12078 wrote:
Here's the reservation system listing for the site we were on at Crooked River State Park near St Mary's, GA last month. The stanchion was a typical 20,30,50 amp park setup.
