jodeb720's avatar
jodeb720
Amp Rating
Ok - I thought I understood electricity ratings (watts, volts, amps).
I know volts and undestand watts is a measure of work - but amps are a capacity.
So when a motor has a rating of 12volts and 12 amps are the amps consumped of amps over an hour (60 minutes)? or is that a constant draw of amps per minute?
If it were watts (it would be volts x amps = watts or in this case 144 watts) - but again, watts are a measure of work - not a capacity or a rating of wires.
This all goes back to me using a 12 volt winch with a 12 amp rating - so if i'm sizing a battery and I expect the motor to run for no more than 10 minutes then i'd use 2 amps if amps are measured per hour.
What am I missing?
Forgive my ignorance, but it's better to ask and understand it than spend money foolishly.
Thanks in advance
Josh
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
